How do I learn Jedicut?
Posté : lun. juin 12, 2017 12:40 pm
Hi All,
I am new to this cnc foam cutting stuff but I do cut wings by hand and I am a technician and quite pc literate. I've tried hard (very hard!) to figure out this program but the tutorials, even when I use Google translate are not of much help. I do understand that it is not a sophisticated bit of software and I thank Jerome for providing this free of charge, but it would be nice to read a really good tutorial.
For example I just cannot see how to set the imported airfoil profiles to the zero/zero line. If I enter a root and tip airfoil they both show as the same size unless I adjust the length of either one in Jedicut. How on earth do you set the span between the root and tip? These are the very basics that should be intuitive...........unless I'm really blind.....or worse! I would sure appreciate some good tutorial in English. Thanks.
Keith R
Keith R
