I'm using a theremino parallel adapter (http://www.theremino.com/en/hardware/adapters#cnc). This setup uses absolute distance mode,G90 gocde.
Has anyone found a utility to convert G-code incremental / relative coordinates to absolute?
Or an updated JediCut plugin that support absolute distance?
Re: G-Code Absolute Distance Mode: G90
2Hello
I don't know if such utility exist.
For the moment Jedicut only generate relative mode. I may work on absolute mode during 2018 if there are interesting people, and brave testers with Theremino adaptor.
Before that I want to work on heating control. I must correct it and improve it.
What software do you currently use ?
3Thanks Jerome.
I'm currently using DevWing Foam. Started with JediCut and have a collection of wings setup for JediCut that I have yet to move to the New Software.
For heat control I'm using a Microprocessor controlled, [b]Constant Current Power[/b] supply with good success. What are you planning on for heat control?
4Hello
Why do you change software ?
I want to improve heating control
