<r>Hello<br/>
<br/>
need your help.<br/>
<br/>
How should I cut this wing with Jedicut.<br/>
I split the wing on 3 segments. Sweep is 24.4 degrees.<br/>
The segment 1 is ready the 2 segment is feasible on my machine.<br/>
My processing. Machine with X-axis at angle 24.4 degrees driving. cut the profile as a straight profile.<br/>
For segment 2, the same process.<br/>
Segment 3<br/>
My machine can not drive this angle, how should I cut this part.<br/>
<br/>
Thank you
<ATTACHMENT filename="zeze001.JPG" index="0"><s> </e></ATTACHMENT>
'KIND REGARDS<br/>
<br/>
Rudi</r>
Re: Help !!!
2Hello,
You have to use a software to rotate your segment 3 and calculate new coordinate in order to reduce sweep.
A french software called "Complex" does this kind of calculation. I should add this feature in a future release of Jedicut.
Re: Help !!!
3@Rudi,
IL Y a aussi un moyen à l'aide d'un fichier Excel.
Pour ceci voir le site : http://papykilowatt.free.fr/
Rubrique dans le menu de gauche :" Les outils pour la CNC "
J'ai utilisé ce moyen et j'avais participé à modifier un petit défaut.
