help is there a English ver of this Jedicut_Alden_ard_ramps_6.pdf
Posté : mer. oct. 03, 2018 9:39 pm
par dpot
hi i am looking for a English ver of this Jedicut_Alden_ard_ramps_6.pdf i ma building the LUXE version and not to sour on the end stops i wont to use Optical End stop i think i just have to run a 5V to it and use the ground and the single on instructions it may be clear to me in English thanks for any help
Re: help is there a English ver of this Jedicut_Alden_ard_ramps_6.pdf
Posté : jeu. oct. 04, 2018 9:19 am
Bonjour, je suis désolé, il n'y a pas de version anglaise de "Jedicut_Alden-ard-ramps_6.pdf". Pour ce que je crois comprendre, vous ne voulez pas installé les fins de courses.
Dans la notice, page 25/34 en haut de la page, c'est expliqué :
Si vous n'utilisez pas les fins de courses, vous devez mettre un cavalier sur la carte Ramps 1.4 ou sur la carte des DB 25.
Le photos accompagnent ce texte.
Vous pouvez copier le texte de la notice et le coller dans google translation, j'ai utilisé des termes simple et éviter les tournures spéciales de la langue française lorsque j'ai rédigé la notice.
Bon courage.
Translation Google
Hello, I'm sorry, there is no English version of "Jedicut_Alden-ard-ramps_6.pdf". As far as I understand, you do not want to install the end of runs.
In the notice, page 25/34 at the top of the page, it explains:
If you do not use the limit switches, you must put a jumper on the Ramps 1.4 board or the DB 25 board.
The photos accompany this text.
You can copy the text of the record and paste it into google translation, I used simple terms and avoid special turns of the French language when I wrote the record.
Good luck.
Posté : jeu. oct. 04, 2018 10:27 am
par dpot
thank you for your reply .
What i am trying to do is use optical end stops that has 3 wires V / S / G.
And not mechanical end stops that only have 2 wires S / G.
I think all i have to do is add a 5V suply to the optical end stop and connet as instruction
Merci pour votre réponse .
Ce que je cherche à faire est d’utiliser des fins de course optiques à 3 fils V / S / G.
Et pas de butées mécaniques qui ont seulement 2 fils S / G.
Je pense que tout ce que je dois faire est d’ajouter un 5V à l’arrêt optique et de le connecter comme instruction
Posté : jeu. oct. 04, 2018 10:56 am
Ok, je vais voir si quelque chose est nécessaire. Avez-vous le schéma des fins de course optiques ?
Ok, I'll see if anything is necessary. Do you have the diagram of the optical limit switches?
Posté : jeu. oct. 04, 2018 9:17 pm
Oui je reviens sur la mise en place de fin de course optique :
- actuellement les fins de course sont à contact, ils sont mis en série et servent qu'en arrêt d'urgence.
- il n'est pas possible de mettre en série des capteurs optiques. Il faut une entrée pour chacun.
Je viens juste de commencer un nouveau sketch en ajoutant le "homing" et le choix de conserver les moteurs sous tension tout le temps.
Je vais intégré le fait que des capteurs optiques sont disponibles maintenant, Afin que le sketch soit compatible avec les différents fins de course, je demande à ceux qui auraient ces matériels de communiquer les schémas des petites plaquettes avec le capteur optique.
Je pense diffuser le nouveau sketch dans 2 ou 3 semaines.
Merci de votre collaboration.
Hello everyone,
Yes I come back on the setting up of optical limit switch:
- currently the limit switches are in contact, they are put in series and serve only in emergency stop.
- It is not possible to put optical sensors in series. You need an entrance for everyone.
I just started a new sketch by adding the "homing" and the choice to keep the engines powered up all the time.
I'm going to integrate the fact that optical sensors are available now, so that the skit is compatible with the different end of race, I ask those who would have these materials to communicate the diagrams of small pads with the optical sensor.
I think to broadcast the new sketch in 2 or 3 weeks.
Thank you for your collaboration.
Posté : ven. oct. 05, 2018 5:12 pm
par dpot
hi sorry for the hassle with the end stops i have optical and Mechanical but both have 3 wires V / S / G
this all i can find on them
so with the optical end stops can we just hard wire start from the end stop to the ramps board and add homing to the sketch
Posté : mar. oct. 09, 2018 9:01 pm
Merci pour les éléments, je travail sur la version Jedicut Alden "SuperLuxe", les fins de course sont raccordés individuellement , Ceci pour des fins de course mécaniques ou optiques. Il me faut un peu de temps pour réaliser un document complet sur les fins de course. Je prévois les schémas de cheminement du câblage du fin de course en détaillant le chemin jusqu'à la pin de l'arduino en passant par la rampe avec les différents types.
Thank you for the elements, I work on the version Jedicut Alden "SuperLuxe", the limit switches are connected individually, This for mechanical or optical race ends. I need a little time to make a complete document on the end positions. I am planning the wiring diagrams of the end of the race by detailing the path to the pin of the arduino through the ramp with the different types.
Posté : mer. oct. 10, 2018 7:52 pm
par dpot
Merci Alain
Posté : dim. oct. 21, 2018 4:01 pm
Bonjour dpot,
Voici le dossier en téléchargement qui traites des fins de course. Ceci est compatible avec la version Jedicut-Alden Super Luxe dont je vais diffuser le sketch et le dossier dans un dizaine de jour.
Bonne lecture.
https://drive.google.com/open?id=1zT62X ... tZCL04E9YF
Hello dpot,
Here is the download file which deals with the end of the race. This is compatible with the version Jedicut-Alden Super Luxe which I will broadcast the skit and the file in a dozen days.
Good reading.
