Page 1 sur 5
Xavier USB adapter info plans
Posté : mar. nov. 25, 2008 10:54 pm
par Mike nelson
Hello Members ; Does anyone Know how I can obtain plans or instruuctions on building the Xavier USB adapter. Thank you!!!!!!!!!! Mike
Re: Xavier USB adapter info plans
Posté : mar. nov. 25, 2008 11:14 pm
You can find all plan on this website
http://www.xavtronic.ch
Enjoy
Posté : sam. nov. 14, 2009 11:38 am
par HCNC
Hi Jerome!
Not work new JediCUT (V2.2.1) with Xavier USB adapter! Old version (V2.2.0) work, bat very slow.
I tested two Firmware (MM and SA).
Please revise modification!
Thanks!
Posté : mar. nov. 17, 2009 9:29 am
par Roland
I confirm that this interface do not work correctly
Posté : ven. déc. 11, 2009 8:26 pm
par robin
Hi Jerome,
I have build the USB adapter (with sincro) and did some some tests with the MM2001 (actually satisfactory with older version of Jedicut, but nothing cut yet - machine building to follow). Please confirm if the MM-USB firmware available on Xavier site is up-dated for 2.2.1 version of Jedicut or I should use the old firmare?
Thanks in advance!
Posté : sam. déc. 12, 2009 9:36 am
I don't find why Jedicut 2.2.1 don't work with Xavier's USB adapter.
Where do you find 2 firmware ? Is there one firmware with clock integrated in adapter, and another using MM2001 internal timer ?
Posté : dim. déc. 13, 2009 11:09 pm
par robin
Yes, one adapter firmware was developed by Xavier especially for MM2001 with external timer from MM2001 (xtc_adapt_MM_V2a.hex) and the other one (xtc_adapt_SA_V1.2.hex) is provided for any Mot. PAP interface i.e. without external timer signal (but I cannot confirm there is one inside the adapter generated by the firmware).
At least in my tests Jedicut v2.1.9 worked OK with the first one at 2kHz and 4kHz timer frequency and not relevant at 10kHz timer frequency; but as I said there were "cold" tests. The PIC 16F874 of MM2001 was burned with MM2001_V51.hex and PIC18F4550 of USB-CNC adapter was written with xtc_adapt_MM_V2a.hex.
Regards,
Robin
Posté : ven. janv. 01, 2010 1:29 pm
par HCNC
In the future too this interface do not work correctly! I tested V2.2.1 build 3.
Only one axis movement, rest not moved. Please check main code!
Posté : sam. janv. 02, 2010 3:20 pm
I'm working on it but whitout CNC board it's difficult...
I attached one file. Can you test it ? I desactivate heating control because it seems to be responsible of problems.
Posté : dim. janv. 03, 2010 3:25 pm
HCNC,
Do you use a USB Hub to connect your board ? Somebody seems to have problem in this configuration...
