Re: Motors resonating
15
Hi again.
I tried MaxCom_XP.dll
But the scale did not match my innput .And the speed figures did not make sense.
I tried many different combinations. But the motors was worse than with visual xp (there the scale was right)
I have read and tested some more .And jused a parrallelport monitor.
And as far as I can understand :
My driverboard needs the folloving signals.
X axis one direction = constant activ low on pin 3 and step pulses (activ low )on pin 2
the oter direction = no signal on pin 3 and step pulses (activ low )on pin 2
Y axis one direction = constant activ low on pin 5 and step pulses (activ low )on pin 4
Z axis one direction = constant activ low on pin 7 and step pulses (activ low )on pin 6
A axis one direction = constant activ low on pin 9 and step pulses (activ low )on pin 8
Do this make sence ??
I hope so
My last post came out wrong.
I misunderstood the Usermanual for the board .
X axis one direction = constant activ high on pin 3 and step pulses (activ high )on pin 2
the oter direction = no signal on pin 3 and step pulses (activ high)on pin 2
Y axis one direction = constant activ high on pin 5 and step pulses (activ high)on pin 4
the oter direction = no signal on pin 5 and step pulses (activ high)on pin 4
Z axis one direction = constant activ high on pin 7 and step pulses (activ high )on pin 6
the oter direction = no signal on pin 7 and step pulses (activ high)on pin 6
A axis one direction = constant activ high on pin 9 and step pulses (activ high )on pin 8
the oter direction = no signal on pin 9 and step pulses (activ high)on pin 8
Sorry
