ENABLE - Lo
Hi, Jerome
My board works with signal ENABLE = 0.
Can You help me?
Configuration:
PC Toshiba Satellite Pro 4200 with W98 >:D<, but with LPT!
CNC SPARTIA by Papy Kilowatt (in progress)
board with Toshiba TA8435H.
With regards, ZbigPL
Re: ENABLE - Lo
My englisch is poor, so my sentences are shorter then ideas.
Jedicut send signal ENABLE =1 (pin 17). My drivers are activated by signal ENABLE = 0.
I had to install inverter (75LS05) at pin 17, but software solutions would be better.
ZbigPL
Re: ENABLE - Lo
#10
Hi!
Once more - configuration:
Windows 98 SE
Board (without timer) input signals (TTL):
ENABLE - active Low
CLK (min 1 µs)
DIR
Using CncNet98.dll or VisualCNC.dll rotational speed is constant and low (about 2,5 turns/10sec) independent on "Speed". I can control direction of rotation.
MaxCom.dll do not work (Win98?).
With MaxCom_XP.dll(?!) I can control the rotational speed ("Speed">80000) but motor not react on signal DIR.
Manualy conecting line DIR to 0V or 5V changes direction.
Voltage levels (0,24V/4,24V) on line DIR are identical with CncNet98.dll and MaxCom_XP.dll.
Do you have some solutions?
ZbigPL
