Page 1 sur 3
ENABLE - Lo
Posté : dim. mai 17, 2009 2:27 pm
par ZbigPL
Hi, Jerome
My board works with signal ENABLE = 0.
Can You help me?
Configuration:
PC Toshiba Satellite Pro 4200 with W98 >:D<, but with LPT!
CNC SPARTIA by Papy Kilowatt (in progress)
board with Toshiba TA8435H.
With regards, ZbigPL
Re: ENABLE - Lo
Posté : dim. mai 17, 2009 7:41 pm
Hi,
I'm sorry, I don't understand your problem :(
Re: ENABLE - Lo
Posté : dim. mai 17, 2009 10:32 pm
par ZbigPL
My englisch is poor, so my sentences are shorter then ideas.
Jedicut send signal ENABLE =1 (pin 17). My drivers are activated by signal ENABLE = 0.
I had to install inverter (75LS05) at pin 17, but software solutions would be better.
ZbigPL
Re: ENABLE - Lo
Posté : dim. mai 17, 2009 10:50 pm
What kind of CNC board do you have ?
Give me your e-mail adress, I'll send to you special dll you will try.
Re: ENABLE - Lo
Posté : lun. mai 18, 2009 1:00 am
par ZbigPL
CNC board is self-made with Toshiba TA8435H drivers.
With inverter motor works.
zcz@epf.pl
ZbigPL
Re: ENABLE - Lo
Posté : lun. mai 18, 2009 7:50 am
With inverter, motor works. But what dll do you use ?
Re: ENABLE - Lo
Posté : lun. mai 18, 2009 12:23 pm
par ZbigPL
Bonjour!
CncNet98 and VisualCNC
ZbigPL
Re: ENABLE - Lo
Posté : lun. mai 18, 2009 8:31 pm
Hi !
You have an e-mail ;)
Re: ENABLE - Lo
Posté : lun. mai 18, 2009 9:35 pm
par ZbigPL
Merci beaucoup, Jerome!
Both dlls work perfect without inverter.
Re: ENABLE - Lo
Posté : mer. mai 27, 2009 12:11 am
par ZbigPL
Hi!
Once more - configuration:
Windows 98 SE
Board (without timer) input signals (TTL):
ENABLE - active Low
CLK (min 1 µs)
DIR
Using CncNet98.dll or VisualCNC.dll rotational speed is constant and low (about 2,5 turns/10sec) independent on "Speed". I can control direction of rotation.
MaxCom.dll do not work (Win98?).
With MaxCom_XP.dll(?!) I can control the rotational speed ("Speed">80000) but motor not react on signal DIR.
Manualy conecting line DIR to 0V or 5V changes direction.
Voltage levels (0,24V/4,24V) on line DIR are identical with CncNet98.dll and MaxCom_XP.dll.
Do you have some solutions?
