Bug Jedicut solved : Slow movement
Posté : jeu. déc. 31, 2009 12:29 pm
Thanks to Frank, I found an error in CncNet and VisualCNC dll files, if you use it with CNC board without external timer.
I will release new dll in few days.
If you try MaxCom dll and if your steppers rrun in only one direction, a solution would be to try the new CncNet or VisualCNC file.
Re: Bug Jedicut solved : Slow movement
Posté : sam. janv. 16, 2010 7:29 pm
par ZbigPL
My CNC can goes faster then 0,5mm/s?!X(
Please, send me new dll's with inverted ENABLE!
Posté : dim. janv. 17, 2010 12:00 pm
Maybe but what dll do you use ? I don't remember...
Posté : ven. janv. 22, 2010 9:06 pm
par ZbigPL
I use CNCNet98.dll.
zcz@epf.pl
Posté : sam. janv. 23, 2010 7:15 pm
par ZbigPL
Jedicut 2.2.2 with oblique and reference position is a big step forward - congratulations, Jerome!
But I must use 2.2.0 build 1 too, because with it i can import DXF Autocad files version 11/12 ASCII.
In upper Jedicut versions it is impossible: Import DXF -> no effect.
When DXF file is improper then I can see: "Impossible d'ouvrir ce fichier." in both versions.
Posté : sam. janv. 23, 2010 8:02 pm
You will fin a new dll in your mailbox ;)
DXF importation is a beta functionality that don't work with all DXF files.
When you click on "Import DXF", do you see a windo when you can select a file ?
Posté : sam. janv. 23, 2010 11:54 pm
par ZbigPL
Yes, I can.
Nothing happens after selection.
