Re: Jeducut with TB6560 4axis cnc board - if possible
Configuration pins of signal on board is:
x dir - pin1
x step - pin16
x enable - pin4
y dir - pin7
y step - pin14
y enable - pin17
z dir - pin6
z step - pin3
z enable - pin5
c dir - pin8
c step - pin9
c enable - pin5
I change to pin spec for Jedi configuration
x,y,z,c but the enable mount all to pin17
Is it possible separate enable to spec, pins?
Before I ask You I change the pins at first time:
X,Y,Z,C to specyfic pins corectly by Jedicut program and my enable signal I mount to 17pin with specyfication Jedicut. But motors runing only by one step. Somethimes runing by clic to right but another clic run to left by one step. The working motors is step by step when I click not non-stop.
Maby working by prefered dll files. ?
I ask you because the my method is bad, motors not working.
Maby i forget something?
#10
Hello
From what I understand it to work properly with the program jedicut need an additional module or signal generator.
The first question is whether it will work with my board which is different from yours. My board is 4axis based on TB6560HQ bought on ebay.
Second question: after the construction of the module where you connect it to the board, little is written about this on your site.
If you send me additional information to my email address it was grateful.
Dan
