Hi Manfred,
it is not possible to download the dll by right-click and "save as" (I tested it with zip-files too). If you do so, you will get an unusable file. To get the dll you need to use a svn tool. If you wont install a svn client you can find a simple tool here: http://downloadsvn.codeplex.com/. It needs no installation. If you use e.g. https://jedicut-extension.googlecode.co ... USBSerial/ for the SVN Source URL you will get all files under this path (set Type to SVN).
Have a nice weekend:)
14
Hi Manfed,
to debug a dll in case you have no debug-able version of the program which uses the dll (in our case jedicut.exe), is a liitle bit tricky. You need to launch jedicut.exe and then using the attach-to-process feature of the visual studio debugger to connect it to the jedicut process. If you have no menu entry for 'attach to process' configured, try crtl-alt-p. After that (and the dll is already loaded) you can set breakpoints within the dll as usual in the visual studio. I hope this helps for starting.
Martin
20
Hello !
I work on Jedicut when I have time and the next step is to publish a small app to test plugin easily. Are you interesting ?
Manfred, what are you working on ? A new kind of adapter without arduino ? Will you share firmware code source, all plans and your Jedicut's plugin source code ?
All this projects are fascinating !
