MM2001 does not work with Jedicut
Posté : dim. oct. 07, 2012 10:55 pm
Hello all. Please help me.
My MM2001 still not to work with Jedicut. With GMFC working properly but does not respond to commands from Jedicut.
Motor LED on MM2001 still not flashing if Jedicut run in cut mode, but but the indicator shows correctly during the cutting process to the end.
I have set CncNet_XP.dll plugin and running on WinXP sp3. Thank you very much. Peter
