Good morning
I have a problem
With my CNC I cut the figure in Annex A.
I imported the profile in jedicut (see Annex B)
On jedicut I see the right profile (see attachments C)
When cutting the foam, the geometry does not match with the program. (See clouds on Annex A)
I state that the axes of the CNC move well, I've tested them with manual control interface of jedicut.
Could you give me some advice?
Thanks
Gabriele
Fichiers supprimés :
Re: CUT Problem
2When you move manual the axis x or y with a value 250mm ,
the axis must drive 250mm.
You can test it and maesure the distance.
Is the distance not correct, you must change in Jedicut the value for "nb mm/pas".
You can make a simple projekt with one rectangle as airfoil and symetric for the wing.
Manfred
Manfred
Re: CUT Problem
3[quote=MAES]
Manfred[/quote]
The axes move properly
I made a rectangle 30x10mm (setting=>symmetrical profile). The CNC cut well.
Then I made a rectangle 30x10mm (setting=>not symmetrical profile). The CNC cut well.
The last test => I add key-points on angles.
The CNC cut well.
I have no more ideas!:(
________________________________________________________
Another problem:
The CNC cut a rectangle 29x9mm. I suppose for wire radiation.
It isn't a great problem, but how I can solve it?
I gone in options/heating and on material parameters I change from 1mm to 4mm in "R1" and "R2"(4mm are many but only for test)
I cut the rectangle 30x10mm but the CNC cut 29x9mm. I thought that with 4mm on "R1" and "R2" the cut will be 32x12mm.(29x9 + 3mm)
How I can solve the problem?
Thanks
Manfred[/quote]
The CNC cut well.
Another problem:
Thanks
Re: CUT Problem
4for the heating you must search in the forum, there are threads for the heating-control.
I use only manual heating.
Manfred
Manfred
Re: CUT Problem
6Allways check "Cutting Wizard" before cutting!
Wire radiation you can account in "Skin property". In your example 0,5 mm (30-29/2).
ZbigPL
Re: CUT Problem
7Hello
I don't know if heating control works very well. I don't have CNC to test.
Like ZbigPlL, I think you don't use cutting wizard. And like Manfred, I advise you to use manual heating first (tu)
