Try CncNet_XP.dll
Re: Hobby cnc pro 4 axis
22Hi Jerome,
Nice software! I have a couple of problems though. Mines a HobbyCNC 4 axis Foam pro board, with heat control and 8Khz timer, Windows XP. I have sync with timer on.
1) I cant get the motors to work with CncNet_XP.dll, it seems to work fine with Maxcon_XP.
2) I don't have heat control! All controls in the heater section are grayed.
-Thanks,
Uttam
-Thanks,
Uttam
23Hello,
You board has to work with CncNet_XP.dll. MaxCom isn't compatible with heanting control.
Do you check "synchronize with external timer" ?
Enter speed value like 5 or 10.
24Hi Jerome,
Thanks for the reply. Yes, I have checked sync with ext timer. When you mean speed value of 5 or 10, do you mean 50000, and 100000? What units is the speed value in?
-Thanks
Uttam
-Thanks
Uttam
25Hi,
If you check this option, you have to configure 4, 5 or 10 in speed value. There isn't units, because Jedicut is compatible with many kind of CNC board...
27Hi,
I have the same board, hobby CNC PRO 4 axis, no timer, no temperature control. I've got it working with the following setup:
DLL: maxcom_XP.dll
speed: 700 slow - 500 fast ==> with this setup I have 10mm in 2,6 seconds with fast speed - I think I can go even faster decreasing those values.
Timer options is disabled
The board is configured for 1/4 microsteping, with this setup my machine has 0,00135mm / step.
I hope it helps to solve the problem.
regards, Marcio
DLL: maxcom_XP.dll
regards, Marcio
