Dear Jerome:
I am making a set of blades for my wind turbine. Your program looks promising.
My goal is to make a blade that is 3 meters long. It will be 5 degree open at tip and 10 degree at root. Can your program config to do that? I have checked, but it can't. Is it possible that you add in this function?
Thanks in advance for your help.
Wachara C.
Re: Different twist angles at root and tip
2Hi !
Why don't you cut the wing with a 15 degrees tip twist ? It's the same way
3Dear Jerome:
It won't be the same. The tip's angle will need to small and the root's will need to be big.
Wachara C.
Wachara C.
4Hello,
Excuse me but I really don't understand the difference. Can you explain it please ?
5Dear Jerome:
I really don't know how to explain it. I guess if you cut it the way you say and when you install it you turn it a little to find the angle you are looking for then it is okay. I will probably do that first and let you know if it is correct the way I think.
Wachara C.
Wachara C.
