till not, but if i can help on this project please contact with me.
Ambass
																													Re: Jeducut with TB6560 4axis cnc board - if possible
42Hello,
Can you try this new plugin ? I inverted the general enable signal.
After you try, can you indicate the configuration of parallel port in Jedicut ?
45Hello,
Do you have an external timer on your CNC board ?
If not, it's normal that you don't check the check with the label "Synchronize with external timer" (on your second screenshot in another language).
With this configuration, you can't use speed values like "4" or "10". You must use speed value like 10000000. If it's to slow, try to remove one zero, or divide this value by 2. Step by step, you must adjust your speed value.
If you never see one step done by your motor, there is another problem.
46Ambass
Have you made a parallel crossover lead between the pc parallel output and the parallel input of the TB6560.
The connections are on the last post first page of this subject.
My setup has been working for over a year now with no problems.
I will list all of my jedicut settings here when I return home and check my workshop computer.
Rob
Rob
47Hi Jerome!
I was tried your suggestions, but it doesn't work. nothing to do...
RoB!
Waiting four your settings!!!!
Thanks
RoB!
Thanks
48I,ve been away for a few days. Here are my settings.
Control card TB6560 switch 5 on all other switches off.
Communication:
Active Table------Default
Mode-------VisualCNC_xp.dll
Engines Clock Dir
x1 8 9
x2 4 5
y1 6 7
y2 2 3
Ex Timer 10 Heating 16
Engine on/off 17 11
12
Syn engine rot-------off (no tick)
X1,X2,Y1,Y2 All the same: Nb mm/pas 0.0025 (this is for my 6mm treaded drives)
Cut Speed 50 (0.19mm/s)
Fast Speed 15 (0.59mm/s)
No heating control (no tick)
Hope this helps good luck. Rob
Communication:
Engines Clock Dir
x1 8 9
x2 4 5
y1 6 7
y2 2 3
Engine on/off 17 11
12
49Ex Timer 10
engine on/off 17
Heating 16
Return pin 11
Status 12
Did not attach correctly
					engine on/off 17
Heating 16
Return pin 11
Status 12
