Hi.
Just restarted my cnc project.
Does version 2.3.2 work with windows 98se ?.
I think the last version I had installed was 2.2.2.
Thanks, Rick.
Re: Jedicut 2.3.2 with Windows 98SE
2The last Jedicut release is the best and I didn't change the compatibility with windows.
Maybe you can confirm ?
3Hi Jerome. Thanks for the reply.
The installer package for version 2.3.2 does not work with windows 98se, but the zip does.
My previous version of jedicut was 2.2.0 and i needed to extract pieces from the jedicut.ini file. Got it running though.
I have tried something new .....
Booted my old computer (the foam cutter) with a windows 7 boot cd. It boots the windows 7 WAIK PE3.0. I then ran Jedicut 2.3.2 with the windows 7 dll
for cncnet mm2001. It works !!!.
This could be a cheap way of running jedicut on older PC's ?.
All i need to do is to sort out the screen resolution and some portable apps.
You can also boot the windows 7 WAIK from a flash drive..
Thanks, Rick.
ps Is the Arduino system working okay ?.
Thanks, Rick.
4Thanks for your feedback !
Do you have an error message when you use the installer on Windows 98 ?
I don't know windows 7 WAIK... The next step : you try the same solution with windows 8
The Arduino system works but not the heating control... not yet...
5Hi Jerome.
The Installer package gives the following error on Win98se ...
"The C:\JEDICUT_SETUP.EXE file
expects a newer version of Windows.
Upgrade you Windows version."
Windows 7 WAIK (Windows Automated Installation Kit) is what can be used to deploy win7.
It contains Windows PE (Preinstallation Environment) 3.0.
This is a minimal OS which can be booted from a CD / USB Memory or HDD.
It only runs for 72 hours before rebooting and the licensing only allows it to be used to deploy / repair windows systems.
That should get Mr Gates off my case !.
Now how about Jedicut for OSX or Rasberry PI. !!
6I think there is a path edited by Microsoft for the install problem but I don't find it...
OS X and Raspberry... are you dreaming ?
