Re: Jeducut with TB6560 4axis cnc board - if possible
33
I tried all the dll's and none works.
The only DLL that seems to 'almost' work is the CncNet_win_XP_Vista bit it gets an error popup... see attached file.
When I tell it to do a long movement with the CncNet_win_XP_Vista, ignore the popup error and then use the parallel port monitor and toggle pin 1 (general enable signal)... the motor move.
In any case, the general 'enable' signal is always the opposite of what this board needs.
See controller doc here : http://wenku.baidu.com/view/f6342ad0496 ... 747b4.html
So can I try next. do you have these DLL's with ability to change the polarity
-Doron.
jedicut.jpg jedicut.jpg Vu 102499 fois 179.31 Kio
36
Tell me exactly what you want because I have difficulties to understand.
pin 1 for general Enable signals.
High level signal to enable your board.
Low level signal (0) to unable your board.
Is it right ?
Yesterday I did a quick modification on cncnet_xp.dll to invert high and low level on this signal. Are you sure that you use the dll I posted before and that you choose it in Jedicut's settings ?
37
Jerome,
1) Yes I am sure I put the the new DLL in that directory and slected it. (I renamed the old one to cncnet_xp_old.dll and it showed in the gui menu as cncnet_xp_old.dll)
2) Did you try the Parmon utility on your computer ? On my machine it does not look like you are stetting the motor enable pin to high on ANY of the dll's (I told it it is pin 1 on the DB-25)
3) You can see here : http://wenku.baidu.com/view/f6342ad0496 ... 747b4.html the mach3 settings that my board is using and when I use mach3 is moves just fine.
Thanks !!!!
-Doron
