Page 4 sur 7
Re: Jeducut with TB6560 4axis cnc board - if possible
Posté : sam. mars 03, 2012 4:34 pm
par doron
I am running windows XP.
I have tried them all and they all have the 'wrong' enable signal... (Only vista and windows 7 dll gets error popup ... in french...;(
Willing to try anything you have....
Thanks !!!!
-Doron.
Posté : sam. mars 03, 2012 8:44 pm
Do you try CnCnet_xp.dll and after that visualCNC_xp.dll ?
Can you explain what is "the wrong enable signal" ? Are you talking about the clock of each motors or the general "enable" signals for the board ?
Posté : sam. mars 03, 2012 11:55 pm
par doron
I tried all the dll's and none works.
The only DLL that seems to '
almost' work is the CncNet_win_XP_Vista bit it gets an error popup... see attached file.
When I tell it to do a long movement with the CncNet_win_XP_Vista, ignore the popup error and then use the parallel port monitor and toggle pin 1 (general enable signal)... the motor move.
In any case, the general 'enable' signal is always the opposite of what this board needs.
See controller doc here :
http://wenku.baidu.com/view/f6342ad0496 ... 747b4.html
So can I try next. do you have these DLL's with ability to change the polarity
-Doron.
Posté : lun. mars 05, 2012 9:55 pm
You can try this dll. I inverted the general enable signal as you like. I will answer your other messages tomorrow.
Posté : mar. mars 06, 2012 2:51 am
par doron
the signal is has not changed ...
Also you can see with this utility
http://www.geekhideout.com/parmon.shtml
I now know that pin one (1) needs to be high (and not low as I thought).
I defined Engine on/off as pin 1 in the GUI but according to Parmon software nothing change.... (When Mach3 runs... that pin is green)
I am not sure you are sending the data to that pin.
-Doron
Posté : mar. mars 06, 2012 7:51 am
Tell me exactly what you want because I have difficulties to understand.
pin 1 for general Enable signals.
High level signal to enable your board.
Low level signal (0) to unable your board.
Is it right ?
Yesterday I did a quick modification on cncnet_xp.dll to invert high and low level on this signal. Are you sure that you use the dll I posted before and that you choose it in Jedicut's settings ?
Posté : mar. mars 06, 2012 4:17 pm
par doron
Jerome,
1) Yes I am sure I put the the new DLL in that directory and slected it. (I renamed the old one to cncnet_xp_old.dll and it showed in the gui menu as cncnet_xp_old.dll)
2) Did you try the Parmon utility on your computer ? On my machine it does not look like you are stetting the motor enable pin to high on ANY of the dll's (I told it it is pin 1 on the DB-25)
3) You can see here :
http://wenku.baidu.com/view/f6342ad0496 ... 747b4.html the mach3 settings that my board is using and when I use mach3 is moves just fine.
Thanks !!!!
-Doron
Posté : mer. mai 02, 2012 7:30 pm
par Ambass
Same problem... It's work with mach3 fine but with Jedi won't start...
I have this one:
http://www.ebay.com/itm/4-axis-TB6560-s ... 093wt_1163
Posté : ven. mai 04, 2012 6:46 am
par Ambass
Jerome!
Please develop some kind of solution! please+please+please!!!!!!!!!!!!!!!!!!!
-D
Posté : ven. mai 04, 2012 12:46 pm
I'm sorry but don't know what to do and I don't have this board. May be you can contribute together and offer me this board ?
Without the board, It's to difficult to work, and It needs too time.
Do you try rob's settings ?
