Cutting text
Hi!
I am trying to cut a small text in one go. I've got a dxf file with a single polyline that represents 3 letters joined using additional connectors. When I define a new cut Jedicut appends some weird segments to the Intrado and Extrado. These segments can be seen in both 'Wing Cut' and 'Cycle Of Cut Manager' screens.
Is there any way to make Jedicut just to follow the path in the provided dxf?
Files are available here - https://filebin.net/9qk28gc8eg4tovsj (could not upload files to jeticut.com)
Thank you!
Re: Cutting text
Bonjour Vzgherea,
Oui ,Inelsal a raison, il ne faut pas de polyline. C'est très bien au moment du dessin de réaliser une polyline afin de contrôler le bonne succession des points. Ensuite il faut exploser la polyline avant la sauvegarde xxx.dxf pour l'utilisation dans Jedicut.
Voici après explosion de la polyline et importation dans Jedicut.
Toute les importations xx.dxf dans Jedicut sont à la corde de 100mm. Ne pas oublier de mettre la bonne dimension de vos corde et de mettre l'épaisseur de peau pour obtenir les dimensions de votre dessin.
Hello Vzgherea,
Yes, Inelsal is right, you do not need polyline. It is very good at the time of drawing to make a polyline to control the good succession of points. Then you have to explode the polyline before saving xxx.dxf for use in Jedicut.
Here after polyline explosion and import into Jedicut.
All xx.dxf imports in Jedicut are at 100mm rope. Do not forget to put the right dimension of your rope and put the thickness of skin to get the dimensions of your drawing.
Bonne découpe
Aeroden
Good cutting
Aeroden
