Jedicut aceepts DXF profile, but It won't cut (Icons grayed out)
Posté : mar. mars 25, 2025 7:52 pm
Hi I started using Jedicut many years ago for foam wings. I have not used it often for the last few years because I stopped building models. Now I would like to continue cutting foam with it, but this time, I want to cut other kinds of profiles. For those I am trying to use the load dxf function.
It all seems to work when I load a dxf file, but all of the cut buttons are grayed out. I see the profile in the view, I see all of the coordinates in the panel on the right. But there is no way to proceed to cut.
It seems to me if the dxf has loaded correctly, it should cut it.
I am doing this using an older IBM Thinkpad T43 laptop, running Windows XP, using the parallel port to cut. The version of Jedicut is the latest 2.4.2 downloaded today from your website and freshly installed.
I've attached the foam cutting file dxf. Thanks very much for your help!
