Jedicut with Hobbycmc board timer problems
I'm Trying to set up Jedicut with the HobbyCNC board with timer and autoheat, using the CNCnet driver. Windows XP version of driver.
It should work with the timer control, but only works with the timer control turned off (unchecked).
The timer is working with Fcut so I know it isn't the board. I uninstalled Fcut and it's driver to be sure it was not interfering, and that didn't help.
What am I missing??????
Is there a way to see in Jedicut if the timer is getting to the program??
Re: Jedicut with Hobbycmc board timer problems
Never mind, found the problem. Had speeds set too high for timer use.
Now a question. How do I set the program for a 'trapezoid' wing. To get an accurate airfoil shape, the wing root and tip have to set parallel to x azis's. How to you get the wire to start of the shorter tip side? Do you have to move it there manually before cut?
Thanks
