Hi,
I had purchased the 4AUPCWHC rev4 board from homecnc.
I had just completed assembly of the board and set the Vref on the board for all 4 stepper motors. I have not hooked on the motors yet.
I have a PC loaded with Windows XP Pro edition which I hope to use with the board and Jedicut software.
Can someone kindly advise what steps I should take next? I have downloaded the Jedicut software and will install it in my PC this afternoon.
Thanks in advance for the help.
Re: Need help to setup Hobbycnc board with jedicut
2Hi,
After installing Jedicut, you have to configure it going to Options form. The first step is to choose un dll. Choose CncNet_XP.dll for your board. You need to set all speed values (if you use external timer, the speed will be set around 10, It depends both on your board and your CNC). If all parallel port pins are set like on MM2001 board, you don't need to do any else.
