Hello!
I have been trying around with jedicut for while, and so far it is working great, but I simply could not find out whether there is a possibility to set up the kerf correction (that is, the amount of foam the wire eats up at different speeds).
Is there a possiblity to do that? As far as I understand this is necessary to cut accurate forms without having to take care of that at drawing time, which would be very cumbersome.
Thanks in advance,
Balazs
Re: How to configure Kerf Correction?
2Hi,
Yes you can do it ! For each cut, you have to fill "skin" field on the wing cut form. You can set differents value for root and tip profiles.
