Hi robert,
On this thread I ask french Jedicut and MM2001 users to post their Jedicut.ini file. There are actually 2 answers, and it works.
I think that someting on your operating system is in conflict with Jedicut like another driver (GMFC driver ?).
I hope you'll find the solution.
PS : It's normal that the motor signal is a little bit different between Jedicut and GMFC.
Re: Jedicut "VS" GMFC
22Hi, Jerome!
Yesterday I have borrowed an old "empty" PC, with only WIN 98. I have downloaded "Jedicut" and everything was OK. Obviously, is in mine both PC`s, Jedicut in conflict with something. I have to find with what.
I have still noted, that in the same time when in the window "cut in progress" a new blue rectangle appears, the motors ( and heating currant) become one irregularly "impulse". Is that usual?
Regards Robert
Regards Robert
23Hi !
It's a good news ! When you see a blue rectangle, the processor usage will be equal to 100% and Jedicut can't work. The question is : What process use all processor ?
Questions on drivers compatible with GMFC
24Hi,
I am new in this area and i would like to seek some help.
Can I know what are some of the drivers (other than MM2001) that are compatible with GMFC?
I read that there is a need to introduce a timer module if the drivers are not MM2001. Can you help clarify on this?
Thanks in advance
Rgds,
Shaoming
Thanks in advance
Rgds,
Shaoming
Re: Questions on drivers compatible with GMFC
25Hi,
If your cnc board doesn't have timer, you can use Jedicut. If you buy an additional board with a timer, you can use Jedicut too, and GMFC.
26Hi Jerome,
Thanks for the prompt reply! I will use Jedicut to spare me the hassle of getting a timer module. Thank you again for your help
Shaoming
Shaoming
