Page 2 sur 2
Re: A couple questions about cutting shapes
Posté : lun. juin 02, 2008 9:59 pm
I'm still working on heat control but I need time...
Posté : jeu. juin 26, 2008 11:35 pm
par SteveC68
Jerome,
Now that the heat control is finished are you going work on the cutting wizard? Luke's problem about trying to cut two different shapes square at one side and a circle at the other side and then Jedicut cutting a shape that is neither a square nor a circle.
Steve
Also I was playing with the fuselage cut tool and I don't see where to align the two shapes.
I used Photoshop to try and show what I'm talking about in the attached file.
Posté : jeu. juil. 03, 2008 10:49 pm
Hi steve,
You ask a difficult function. First I need to control my heating control because there is some problem, but after that I'll take a look at this
Posté : mar. sept. 02, 2008 11:31 pm
par SteveC68
Jerome,
Have you fixed the problems with the heat control?
Luke,
Did you see the same error in the shapes if you use the default cutting wizard offsets of 10mm? You said the error got worse as the offset increased and I wasn't sure if you had tried with a really small offset.
Steve
Posté : mer. sept. 03, 2008 8:00 am
What problem are you talking about ? Jedicut 2.1.9 fix an important problem with heating control and I'm still working to improve this functionality
Posté : mer. sept. 03, 2008 6:16 pm
par SteveC68
On July 3rd you said this:
Hi steve,
You ask a difficult function. First I need to control my heating control because there is some problem, but after that I'll take a look at this.
I was asking if you had fixed the problem.
It seems based on Luke's and others comments that in the cutting wizard that the larger the offset is set then the larger the error in the cut. I would think this is a higher priority than the heat control as heat control can be adjusted manually outside of Jedicut.
Steve
