are running jeticut interface BB2001z to cut wings for model aircraft and are finding difficulties the configuration.
1 - want to cut cut a wing to wing root to wing tip and 195mm to 156mm, when we sent it to cut the cycle is put with only
30mm + or --
2 - the centralization of the beginning of the cut in Styrofoam. preview window cut in the profile is out of Styrofoam.
believe that our problem is being measures.
grateful for the attention
Walmyr from Brasil
Retourner vers « Jedicut - English board »
- - Machines CNC & Mécanique
- - Plugins pour Jedicut
- - Jedicut - English board
- - Aero 2009
- - AeroMicro
