Re: Jeducut with TB6560 4axis cnc board - if possible
45
Do you have an external timer on your CNC board ?
If not, it's normal that you don't check the check with the label "Synchronize with external timer" (on your second screenshot in another language).
With this configuration, you can't use speed values like "4" or "10". You must use speed value like 10000000. If it's to slow, try to remove one zero, or divide this value by 2. Step by step, you must adjust your speed value.
If you never see one step done by your motor, there is another problem.
48
I,ve been away for a few days. Here are my settings.
Control card TB6560 switch 5 on all other switches off.
Communication:
Active Table------Default
Mode-------VisualCNC_xp.dll
Engines Clock Dir
x1 8 9
x2 4 5
y1 6 7
y2 2 3
Ex Timer 10 Heating 16
Engine on/off 17 11
12
Syn engine rot-------off (no tick)
X1,X2,Y1,Y2 All the same: Nb mm/pas 0.0025 (this is for my 6mm treaded drives)
Cut Speed 50 (0.19mm/s)
Fast Speed 15 (0.59mm/s)
No heating control (no tick)
Hope this helps good luck. Rob
