Hello!
I am new in foam cutting, and I try to cut first wing core using Jedicut.
Firstly, I would like to know about good way to use jedicut with board which don't have any timer. I use industrial stepper
motors controllers, which are connected straight to LPT port (step/dir signal). Temperature is regulated by big npn transistor also connected via transoptor to LPT.
I've tried use every driver - MDLCNC works, but motors aren't synchronized.
Secondly I add that, with other programs like Mach3mill my cutter works perfectly.
I'd like to make jedicut work, because I found this program very nice, and quite useful.
Greetings from Poland!
Michał
Re: Jedicut without timer
3Hello.
I meant, that motors hadn't worked correct. During cutting or only move - motors are moving, but this move seems to be a chaotic.
However I found good solution. I built timer, which generates 0,5 ms synchronising signal (connected to 14 PIN) and now device works.
First pair of cut wings, has already flown.
Thanks for help.
Thanks for help.
4I think that you used too small value for speed configuration. But if you solved the problem with an externat timer, congratulation !
Do you tell us where do you find the plan of the external timer ?
5Thank you.
I used AVR uC with few lines of code, but there is similar construction which can be found at GMFC website in "Interface boards" called "Quartz based timer".
I think I'll improve my cutter with better PWM wire heat control, which offers MM2001, but I still have no good solution to connect external motor drivers with this board.
Greetings
Michał
Greetings
Michał
