Page 1 sur 4
Problem with DXF
Posté : mar. nov. 23, 2010 3:34 pm
par suri
I can not import any DXF file into Jedicut. I tried out Corel X3 and the Alibre. I also tried downloaded profiles from web. What is the correct format? I have Jedicut version 2.2.2. Please help. Thank you.
Re: Problem with DXF
Posté : mer. févr. 16, 2011 5:20 am
par DAN
Hi I,am having the same problem. I tried DXFr12 in autocad, but it didn't work so I tried all the DXF in autocad.still didn't work. does anyone have a solution. DAN
Posté : ven. juin 03, 2011 4:22 pm
par Steve Redmond
It seems that Jerome has successfully imported the .dxf format from an old OEM version of CorelDraw. If we knew which version of Corel this was, and what Autocad version of .dxf it outputs, we might be able to mimic this with other software.
For instance A9Converter:
A9converter
Also another possible problem is not knowing the steps are needed to input a .dxf into Jedicut properly.
Do we do that when we first open Jedicut? Or later when choosing a profile? And what do we see when we do successfully import it? Are we switched into profile view? Or is the imported .dxf available to pick as a profile, like an airfoil?
Without understanding how to import the .dxf, or what happens when we do, or what actions we are supposed to perform, we may just not be doing it right.
Perhaps it is properly importing, and we just don't know it.
If we could get these things clarified, I'd be happy to write up a Help section for using it.
Posté : mar. juin 14, 2011 3:51 pm
I worked on DXF R12 specification. I'm actually working on a new solution more powerful with the new plugin architecture. I first work on classic format like dat to validate the soluton with Jedicut and after that, I will work on dxf compatibility.
Posté : mer. juil. 27, 2011 5:33 am
par Steve Redmond
Jerome,
would it be possible for you to post a .dxf file here that does import successfully into Jedicut, so that we can examine its content, and then compare it with the Autocad 12 files we can't get to work.
Maybe the problem is something very simple, like a header change. We could then fix our files and get Jedicut to accept them.
I know you are working on more elegant solutions for the future , but many of us really need to cut a DXF object right now. If the problem is something simple, we should be able to spot it in the file.
Thanks!
Posté : ven. août 05, 2011 6:39 pm
Hello !
I worked on a new dxf plugin aller this week. I will post a new Jedicut beta release on the next days. Maybe be are you interesting to test it ?
This solution is more powerfull and complete than the last one
Posté : sam. déc. 17, 2011 11:19 pm
par hornet20
I have the similar problem, I use last version of jedicut with plugin for DXF. When I try open any files, in open window I can use only *.jdc *.jdp *.prf *.dat v0.1. My jedicut don't see any other files in open window.
I donwload the jedicut in zipfile on pendrive, now I can open dxf on one coputer, but when I use it (the same pendrive) in home computer, dxf in jedicut dont work
Jerome, could you tell me if I should install diffrent aplication,plugins etc ??
Posté : dim. déc. 18, 2011 7:02 pm
Hello !
It's not the same problem because you use the new solution, more powerful when it works...
What version of windows do you use ? Can you post a sample of dxf file you try to open with Jedicut ?
Posté : dim. déc. 18, 2011 11:20 pm
par hornet20
I use windows XP with sp3. Update sample of dxf is not nesesery, I can't open any dxf files, because in open window (file / open) I can't choice DXF type. Of course then I cant see any dxf files.
When I used jedicut without dll-patch I cant choice the dxf file, only .jdc *.jdp *.prf *.dat. Now, when I have dll patch when I try open the file I can choice file type: .jdc *.jdp *.prf and diffrent *.dat V0.1
I think dll patch works, but no sufficient.
Posté : lun. déc. 19, 2011 7:54 am
When you install Jedicut with it setup file you don't see *.dxf, and when you copy ALL dll files available with the zip file, you also don't see it ?
I have a win xp sp3. I'll try it again tonight or tomorrow.
