I have tested with my old desktop, plug-in CncNet_win_xp_vista_7_32_x64, and Windows XP SP3.
I obtain this error with Jedicut 2.2.2 build 0 version, when the cut wizard appear just before a cut cycle, right ?
With Jedicut 2.2.2 build 1, I don't obtain this error.
Re: Parallel port address
22rob Wrote:
> Steve
> The lpt 3 (pci card parallel port) the basic
> Basic Configurations in Printer Properties are not
> accessable see settings 2 post 10.
> Rob
There's a setting somewhere that will allow you to change that. Don't have time to research it right now, and I run Linux, not XP generally. But a little research on the net will find an answer to that for you.
You should also find out what port your bios is assigning if any, or if it is set to allow the OS to set ports.
> Steve
> Rob
23Vincent
That is correct I can only see build 0 . File verison 2.2.2.0 on the jedicut icon.
Where can I find build 1.
Thanks
Rob
Thanks
Rob
24Hi,
Rob, the Jedicut 2.2.2.1 (build 1) beta version is here :
http://www.aeropassion.net/blog/dc-site ... .2.2.1.zip
25Hello Vincent
In what order should I install the files please.
I have got a 10 year old desktop pc with xp installed up and running with a motherboard parallel output. 2.2.2. build 0 is running with no problems. Just got to find somewhere to put it in my workshop:)
Thanks once again I am going on holiday today will try with the PCI card again in 3 weeks time.
Rob
Rob
26Hello,
You can save in another folder your jedicut's folder. So just unzip the archive in jedicut's folder, that's all :-)
Replace all files.
Replace all files.
