Hallo Jerome,
With try and error I got an answer of my Problem:
If asked to give a data in a field, one is asked for mm. But you must enter 1/10 mm. Examble: The profil shall have a lenght of 200 mm, you have to enter 2000 mm.
At the window with separat moved X1,X2,Y1,Y2 it seems to be exchanged slow and fast ???
The main problem is the absent of descriptions what entering of a variable effects.
Did you get my e-Mail?
Sincerly Laubi
Re: The stepper ist allways to slow
12hello
I received your mail.
There is no exchange in speed values but I will verify again
What do you use in "mm/step" value in Jedicut settings ? With the problem you described, you should multiply this values by 10.
13Hallo Jerome
I tried to plot a profil with Holm. The round profils are ok. But not the rectangular, see attachment.
have you an idee?
Laubi
have you an idee?
Laubi
