Does Jedicut work on windows7 in either 32 or 64 bit mode?
I am wanting to get a new pc to work with my HobbyCNC board.
Re: Windows 7 and Jedicut
2Hello !
Yes it works on Windows 7 if you use the right plugin of communication.
3Hi,
What do you mean plugin? USB board or software? If software, where do I find the plugin?
thanks alot
Ian
thanks alot
Ian
4Hello
When you will install Jedicut, you will select one plugin in Jedicut settings that works under windows 7.
5Could you tell me which one if for window 7 32bit and which one is for window 7 64bit? I am trying to set up a new cnc cutter with a mm2001 board.
Thanks
Don
Thanks
Don
6Hello
You must use the plugin with "32_x64" in its name. It works on Windows 7, 8, 8.1 and it may works on Windows 10, both 32 and 64 bit release.
7[quote=Jerome]
Hello
You must use the plugin with "32_x64" in its name. It works on Windows 7, 8, 8.1 and it may works on Windows 10, both 32 and 64 bit release.[/quote]
Jerome:
Thanks for getting back so quickly with the answer.
Have a nice week.
Don
Hello
Jerome:
Have a nice week.
Don
