JediCut stops
Hello.
I found some problems using a JediCut.
My machine worked for some time on GMFC, but now i wanted to use JediCut and very often when i run the engines (doesn't matter which mode or direction) the stepper motors stop during the work (the progress bar is still going while the motors aren't working).
Can i fix it somehow? I tried to change the .dll files but it's nothing
Re: JediCut stops
What plugin of communication do you use ?
Do you you use Jedicut on the same computer than GMFC ? Some people indicate that they have to completly uninstall GMFC because its parallel port drivers block other programs.
My last question : why do you want to change software ?
Re: JediCut stops
The computer is the same for GMFC and JediCut, and i'm using plugin for MM2001 French board on XP.
I would like to change the software, because i'm not the only one using the machine, but the only one knowing english to use GMFC. The Jedi cut is in my national language so it is easier to use it both for me and my friends. Also i found the interface more friendly than on GMFC
