Hi,
I am having problem with Widnows 7 64 bit. I get "Unable to start the IO.SYS Service. Error code = 1275" error message for 5 times every time I start the program or when I go into the "options" page.
Did anyone resolve this?
Thanks,
Rony
Re: Windows 7 64 bit error
2Hallo Rony,
have you install the last version from Jedicut?
Exist on your PC a LPT-Port?
When "yes" you must under Win7 under Option-Communication take the CncNet_XP_Vist_7.dll.
If the Error not go away,
you can test with the Xavier.dll under Option-Communication.
With this Plugin the Error must go.
4Hi,
IO.sys doesn't work with win 7.
It must be delete from the jedicut's folder if win 7 is used, like others old plug-in witch use this file.
You should uninstall and delete all jedicut dll files, and install lastest version with the installer, not with the zip with copy old files.
5Hi,
I deleted all the DLL from the DLL directory except the USBSerial.DLL (I will be using Arduino).
Now everything is working without errors.
Thanks,
Rony
Thanks,
Rony
