Cut speed
Hi Jerome
I set cut speed but I don't know for what point of wire it is calculated: X1, Root, Tip, X2 or another.
It is important when root and tip chord are significantly different.
Can you explain the problem?
ZbigPL
Re: Cut speed
Hi Jerome
My question was half-baked.
I want to make sure, your algorithm uses max cut speed on the side where is more steps to do.
Eg. Jedicut sends sequentialy 10 steps on X1 side and 1 step on X2 side - max speed on X1 side and 10% on X2 side.
In addition I have a little problem with Cut wizzard.
A little triangles are added at the corners. Sometimes it disfigures the shape.
Do you have any remedy for this?
ZbigPL
Jedi_corners.JPG Jedi_corners.JPG Vu 8251 fois 38.73 Kio
Re: Cut speed
4
Jedicut always use cut speed for cutting. The cut speed is the upper speed using by each steppers when you cut.
For the cut wizard, it should be a miscalculation. Do you try to move foam to the extrem left of the table, near motors (or to the extrem right) ?
