Hello, I'm from Brazil (MG). Are you using cnc Shield v3 + a4988? you have to contact you via email (email etc). Thank you.armo a écrit : ven. mars 16, 2018 1:14 am Hello all! I´m Alfredo from Brasil. I just finished a arduino uno board with a CNC shield v3. I´ve followed all instructions given by TJMarch on post 207. The motors were tested and all four are working outside jedicut. I did the jedicut configuration using the same parameters as TJmarch on the same post. When I start Jedicut look´s like it is not comunicanting with arduino. I could not find a place to tell Jedicut what port my arduino is using. I do not çnow if is necessary to change the lpt port# to a usb port#.
Best regards to all
Alfredo
223Bonjour,
Dans le répertoire de Jedicut il doit y avoir le fichier "comport.ini", c'est un fichier texte qu'il faut modifié pour que le port corresponde.
La dll "USBSerial.dll" doit être dans le sous répertoire "Dll"
A bientôt.
Code : Tout sélectionner
C:\Program Files (x86)\Jedicut\
DIR Decoupes\
DIR Dll\
DIR Lang\
DIR Profils\
25 ini adresse_port_LPT.ini
301 ini comport.ini
46592 dll ddddio.dll
128 txt GCode_by_Jedicut_277785497.txt
128 txt GCode_by_Jedicut_278565931.txt
98304 dll inpout32.dll
6121984 exe Jedicut.exe
809 ini Jedicut.ini
2357 ini Jedicut_Default.ini
2379 ini Jedicut_df_600.ini
2379 ini Jedicut_GR_600.ini
346624 dll Jedipix.dllCode : Tout sélectionner
C:\Program Files (x86)\Jedicut\Dll\
99840 dll CncNet_win_XP_vista_7_32_x64.dll
90112 dll CncNet_XP.dll
90112 dll CncNet98.dll
89600 dll Frank.dll
89088 dll GCode.dll
89088 dll MaxCom.dll
89088 dll MaxCom_XP.dll
89600 dll MDLCNC_XP.dll
88576 dll Start.dll
63488 dll USBSerial.dll
94720 dll USBSerial_2.dll
89600 dll VisualCNC.dll
89600 dll VisualCNC_XP.dllA bientôt.
224Hello,
first I want to say thank you for your work on the USB sketch for arduino. It works well for me, besides from the PWM for heating.
In my case it is reversed and I do not know why. When I have 100% in jedicut, the PSU is on 0A - when I have 1% in Jedicut, the PSU is on 4A etc..
Can you tell me, what I have to change, that 100% = 4A and not reversed?
Thank you in advance.
Marcus
Marcus
Jedicut 2.4.1 build 0 * Letmathe MDLCNC-T4V5 * arduino UNO with fcifmdlcnc.ino + DB25 adapter * MeanWell NPF-120D-24 for PWM controlled heating CC * 5V->10V PWM http://birota.azurewebsites.net/0-5v-to ... r-arduino/
225Bonjour,
Pouvez-vous nous préciser si vous utilisez le schémas du dossier Jedicut-Alden avec la puissance PWM de la carte Ramps 1.4 ou si vos utilisez un autre générateur indépendant commandé par la Ramps 1.4 ou le signal de la carte Arduino en direct ?
A+ Alain
Can you tell us if you are using the Jedicut-Alden folder diagrams with the PWM power of the Ramps 1.4 board or if you are using another independent generator controlled by the Ramps 1.4 or the Arduino live board signal?
A+ Alain
