Thank Martin for this explanations.
So the pins configuration in Jedicut's options will be always the same for all CNC interfaces.
It's the cable between arduino and CNC board witch will adapt controls bytes for differents CNC interfaces.
I think it's a good idea to add the "delayMicroseconds " parameter in comport.ini, to adapt delay for different board, instead of recompile the code every 30 seconds to test :p
Jerome, Ok for the photo, i'll do it.
42In progress (:D
to match with axis assignment in Jedicut's manual control :
[pre]
Axis Jedicut pin mm2001
X1 3 (step)
8 (dir)
X2 9 (step)
2 (dir)
Y1 5 (step)
6 (dir)
Y2 7 (step)
4 (dir)
[/pre]
[pre]
X1 3 (step)
8 (dir)
X2 9 (step)
2 (dir)
Y1 5 (step)
6 (dir)
Y2 7 (step)
4 (dir)
[/pre]
44Jerome,
i have a question to the heating-control.
When i write a 2-byte command from arduino to the USBserial.dll with include the value from the heating-pwm(0-100),
is it possible that you read this value in Jedicut?
45Martin,
If I understand we can continue to affect dir and clock pin number in Jedicut ? For the others it depends on the CNC board and the cable.
Vincent,
Thanks for the photo ! I can't buy this arduino, it's in backorder
MAES,
Jedicut can read the heating value returned by arduino if you use the right function in your plugin
Vincent,
MAES,
46Jerome,
in the plugin i can not find the funktion who i can Jedicut tell the PWM-value.
Can you help me?
Manfred
Can you help me?
Manfred
47Manfred,
It's the "LireChauffeMachine()" function. When it's called by Jedicut , it return a decimal value ('double' type ) witch is the heat value calculated by the plug-in with the PMW signal heat built by the CNC board.
In the source code of USBSerial.dll, this function return always 'O' :
JEDICUTPLUGIN_API double LireChauffeMachine()
#ifdef DEBUG_OUTPUT
fprintf(fp,"LireChauffeMachine:\n" ) ;
#endif
return(0);
#ifdef DEBUG_OUTPUT
#endif
return(0);
48Vincent,
thank you, i have found it.
0-100% = a return-value 0.0-1.0.
Manfred
Manfred
49Here is the code for PWM to Jedicut.
From Arduino i send the PWM-Value in 2-bytes.
'H'and value.
changes in dll.
void checkInput()
int n;
char inBuf[2];
ReadFile(hCOM, &inBuf, 2, (LPDWORD)((void *)&n), NULL);
//if(n=1)
switch(inBuf[0])
case 'S': // stop transmission
mcBusy = true;
break;
case 'C': // continue transmission
mcBusy = false;
break;
case 'E': // Limit switch hit TODO
break;
case 'A': // Stop the complete cut TODO
break;
case 'H': // Stop the complete cut TODO
PWM_Value = inBuf[1];
break;
default:
break;
double PWM = 0.0;
PWM = (double)PWM_Value/100.0;
#ifdef DEBUG_OUTPUT
fprintf(fp,"LireChauffeMachine:\n");
#endif
return(PWM);
PWM_Value must global.
i have engineer code for a dsPic-controller,
so i can not send the code for the arduino.
Manfred
'H'and value.
changes in dll.
void checkInput()
int n;
char inBuf[2];
//if(n=1)
switch(inBuf[0])
mcBusy = true;
break;
mcBusy = false;
break;
break;
break;
break;
default:
break;
double PWM = 0.0;
#ifdef DEBUG_OUTPUT
#endif
return(PWM);
Manfred
50Hi everybody !
The tests progress...But now, there's a problem with the motor's direction...It's almays the same ::o
Even the "invert" option cases are checked in Jedicut options, or in manual control with a negative/positive travel value...
Probably a problem with pin's direction assignment, but I have already re wire them to test, and nothing to do, no changes...
