Re: carte contrôleur commune
Hello Rui,
You must connect the "step" and "dir" pins of your interface with a parallel port, and configure Jedicut to obtain the correct assignation of the pins "step" and "dir".
For example, connect the "step" on the pin 2 of the parallel port, and "dir" on the 3rd pin.
Launch Jedicut, go to "tools", "options", "communication", and select correct pins assignment : 2 for the step, and 3 for the direction.
Your motor should turn if you send an order in manual control.
