how to generate a gcode with cut compensation?
hi i'm trying to use jedicut to make the gcode for my cnc machine, i set all the parameters but i can't generate a gcode with the cut compensation, i wanted to know where i am wrong and if there is a guide, a greeting
Maybe some information was missing on this post, I wanted to integrate them with photos and sample files. If the compensation works using different materials I should get completely different GCODE and instead I get the same, how can you generate a file with the cutting radius compensation?
