Re: Control pin outs for the printer parallel
Hi,
I think you'll have to search documentation on parallel port. Jedicut don't fix +vdc or -vdc value. You can design your board like on MM2001 or Visual CNC. In Jedicut you can configure all your parallel port pins but actually Jedicut only control motor connected to the data register of your parallel port (4 motors with 2 pins per motors = 8 bits).
