Heat control issues with HobbyCNC foam Pro board
Hi
Is there anyone using the HobbyCNC Foam Pro board with on board heat and timer control?
Got everything running perfectly on Jedicut except the heat control. The moment I boot my board the bow heats to its max temperature and I cant control the heat with either Jedicut or the actual board switches and controls :X
Jedicut recognize the Manual/Auto heat control when I switch between the different modes its just that I can’t switch the bow heat on or off neither can I control the heat.
I suspect that the MOSFET powering the bow might be faulty which is obviously my board problem.
Would really appreciate any comments/suggestions
Thanks
