Profili and Jedicut interface - File Preparation
I'm very new to Jedicut.
I've built my HobbyCNC board and run some of the Jedicut files on it
with the steppers all just sitting on my bench.
I put tape on the shafts to watch them rotate easier.
What I currently have in addition to Rhino is Profili Pro 2.8 or whatever.
AND possibly I should be asking in the Profili forum, but here goes ...
After setting up a Wing panel with Foil, spars, etc in Panels Management I save and then ...
I have found that doing the 4-axis output as Dat does not work.
That is to say IF I save individual dat files for root and tip THEY are invisible in Jedicut ???
but,
IF I select in 4-axis output as DXF then importing it and re exporting it as dat DOES WORK !
Is there a secret to this tedium ?
Does Jedicut prefer a specific "Type" or " Version of DXF ?
ALSO:
After Profili does a wonderful 3D simulation it outputs a Complete 4 axis DAT file if you choose.
Is there any way to actually USE that file in Jedicut ?
I currently get a very confusing and obscure display when doing that.
As you can see, my biggest problem is file preparation.
I already have a CNC router and cut lots of foams parts.
The Finer nuances of 4 axis operation just seem to be elusive.
ANY pointers or primers would be helpful.
Thanks in advance.
Bob
