error message
Hi Jerome and others:
I just downloaded the new 2.1.1 version, and when trying to move motor ( with or without interfase connected) I get the error " Time out ".
What is the meaming, or what to do? is it a bug or what?
I re installed the program and run it again with the same results.
Any idea?
Thanks , Jorge
Re: error message
Hi Jerome:
The card is a brand new homemade MM2001 made following the cnc-net dossier.
Modified to accept wire conection for the motors, instead of flat wire connectors.
Plug in selectedis the cncnet XP.dll one, because that´s the system I have.
Pic was programmed by a friend, outside the card , due to programming limitation to Win 98.
Program used is the early one, not version 2.
And I can not test it on GMFC, ( just to check the card) because the trial period has expired!
Jorge A.
Re: error message
Hi Jerome
Yes, seems like that. Rechecked all connections, welds, etc.but nothing seems bad.
Only mistery is pic programation...
Or should I change something else on the cpu configutation?
During the weekend I´ll be reprograming the pic with the version 2 software, and try to test it on another cpu. I understand that can not use my win XP machine to run the programation soft, right ?
Is there any problen using Jedicut and Win 2000 based machines ?
We shall see,... light or smoke !
Jorge A.
Re: error message
Hi,
It's not a system problem, nor a Jedicut one. I really think that it's a CNC board problem because Jedicut can't read external timer signal. What's your speed configuration ? Can you control the timer signal on pin 10 of your board parallel port ?
Re: error message
#8
Hi Jerome:
Answering your questions:
1000000 for cutting and 500000 high speed, I have also tried from 2000 up to 2000000 for each motor, but no difference.
Changed the Xtl ( 16 Mhz ) rechecked al solders and reprogrammed ( externaly ) the pic with v2 hex.
Now the time out message is not present, but still not working.
This is a mm2001 board . I think there is no possibility to control timing. Right ?
If there is any way, how can I do that ?
Hope not blowing the parallel port during the weekend.
Jorge A.
Re: error message
#10
Hallo Jerome:
Yes, oui, si, ya, da ... it works!!!!
Question, why with so low values ( 10 and lower) if i´ve seen 1000000 and higher numbers on the configuration messages ???
How does this number works, and what are the limits ???
Now I´ll continue with the heating power card.
Jorge A.
