Re: Single pass cut?
Hi,
Skin thikness don't work with all profiles. I have to improve it. Since last Jedicut verison I don't change it.
When you open the "Cycle of Cut" window configuration, you can see a checkbox between all others steps options called "inverse". This check box is enabled only when you click on extrado or intrado in the steps list.
I assume a 'single pass cut' is when the hotwire cuts around the profile without having to do the top and bottom in seperate runs.... then how does clicking the 'inverse' box in the wing page change anything? I look at the cycle cut manager , after clicking inverse (as explained above) and their are lines in weird directions, it doesn't make sense. Help! :-)
