No, directly connect PC USB - Xavier boar!
Old version (JediCut) good works with Xavier board (bat very slow motion available only)! Only new version not work!
I see Xavier dll (in old and new version), bat they are alike...
															Re: Xavier USB adapter info plans
12Hello Jerome!
New version (V2.2.2) work with Xavier USB board and speed is more, Thank You!:)-D
I found a problem: if not use Smooth option in manual move, then not change direction in value of +-Move(mm)! Only one direction rotation of step motor. If use Smooth option, all ok (bat under such less speed)!
www.hobbycnc.hu
13Hello,
I'm sorry but I don't know where to search, and without CNc board it's difficult...
Do you receive my last email ?
14Jerome Wrote:
> Hello,
Hello Jerome!
No, please send again!
> Hello,
Hello Jerome!
www.hobbycnc.hu
16I have a problem with version 2.2.2. Basically the engine is x2, which works incorrectly .. I've done several tests and it is not ...
17hallo Jerome,
I construted the Xaver USB board and tried to programm the hex-Files. I connected the Board via USB to the PC. But the PC will not recognice the board.
Can you help me?
Sorry for my Englisch. I speak normally German
Juergen
Can you help me?
Juergen
18Hi there. http://www.xavtronic.ch site does not work. Where can I download firmware.
19Hello,
i have the file's, but to big for the attach.
i will send it to Jerome.
