Re: ENABLE - Lo
> With MaxCom_XP.dll(?!) I can control the rotational speed ("Speed">80000) but motor not react on signal DIR.
> Manualy conecting line DIR to 0V or 5V changes direction.
After inserting capacitor 0,1 µF on input DIR of motor driver I can control direction (MaxCom_XP).
I think you know what happened.
ZbigPL
Re: ENABLE - Lo
13
Hi
Today I test driver-stepper whith simple multivibrator.
Settings:
ENABLE -> GND
DIR -> GND
CLK -> multivibrator output
Motor (1,8 deg/step) goes to about 1500 Hz with 1/1 stepping and 6kHz with 1/4 stepping.
I can set 1/1, 1/2, 1/4 and 1/8 stepping.
Reconnecting DIR between GND and 5V changes the direction of motor.
It looks very easy but we have saying: "Devil seats among details".
Best regards
ZbigPL
Re: ENABLE - Lo
15
Hi, Jerome!
I was on holiday without Internet.
Currently my machine is ready to work.
I succesfully tested it with Foamworks but I hope that I'll can work with Your program.
Machine works too slowly with CncNet98.dll or VisualCNC.dll.
With MaxCom_XP.dll (ENABLE inverted) I can control the rotational speed but not direction.
I sent You driver's datasheet with signal description. Only limitations is CLK > 1 microsec.
It looks that You have to "glue" control the rotational speed from CncNet98.dll and direction control from MaxCom_XP.dll;).
ZbigPL
Logic.jpg Logic.jpg Vu 6987 fois 51.56 Kio
Re: ENABLE - Lo
19
Hi, Jerome!
Test results with modyfied (inverted ENABLE) CNCNET98:
"Speed": from 1 to 40.000 -> Motor: about 1 turn/s (lost single steps)
"Speed": from 50.000 to 1.100.000 -> Motor: about 1 turn/s no reaction on "Speed"
"Speed": 1.200.000 -> about 0,5 turn/s
"Speed": 5.000.000 -> about 0,2 turn/s
Settings:
step 1/1
200 steps/1 turn
Max motor speed is a little to slow.
I can't test MaxCom_XP.dll without inverter, but I remember "speed">80000.
Zbig
ZbigPL
