Where can I find foamcutif.ino. I've looked on Github and downloaded the ZIP file which contained an Arduino map but not the early mentioned foamcutif.ino file.(see earlier in this thread).
I connected an Arduino Pro Mini to an DB25 connector and hope to get my MM2001 interface card to play together with Jedicut software.
Sorry if ai missed something elemetary. I didn't read all the post yet.
Greetings to you all,
Henk
192Oh I see: It's called fcifMDLCNC.ino now. Will load the sketch on my Pro Mini and see what other obstacles come by and undoubtedly report back.
Henk
PS Nobody is watching this part of the forum?
Henk
193Hello !
I'm here but I don't have time every day to answer the questions of forum.
All last versions of files are on github https://github.com/jedicut/jedicut-devi ... fcifmdlcnc
You're right. The name of this file has been changed.
Give us your feedback after you upload and test this firmware
194Hi Jerome,
I noticed wiring directions of Arduino pins in the Arduino sketch are different from those mentioned in the first posts of this topic. Am I right?
Henk
Henk
195Hi
I'm sorry but I don't understand the question. I never try this device by myself but I will. Maybe soon.
Maybe you can just try and tell us your feedback?
196Post nr 1 from Martin ? showed the pin numbering and I soldered the wires to the DB25 connector accordingly, however I found that the Arduino sketch showed otherwise. Will rewire and try again. Will let you know I get on.
Patience please. My experience is that it will certainly not work right away. But if someone is also using the MM2001 board and can give me some assistance I'll be glad.
Greetings
Henk
Greetings
Henk
197Bonjour,
Pour peut-être vous aider, veuillez consulter la discussion ici viewtopic.php?f=5&t=9832
Veuillez utiliser Google translation.
Cordialement
To help you, please check out the discussion here [url] viewtopic.php?f=5&t=9832 [/ url]
Please use Google translation.
cordially
Cordialement
cordially
199Hello to whom ever can help me.
Trying to get Jedicut to work with a Arduino CNC Shield version 3. I have been working on this for a couple days and I am so close to getting this to work but now stuck and do not know what to do.
I cannot get the stepper motor to rotate, they just hum when trying to move axis in manual with JediCut. I have the shield set for no micro stepping and set to use a fourth axis. Following link to info for shield
http://blog.protoneer.co.nz/arduino-cnc ... ide/Shield
I have read all of this thread and have tried changing the following to higher number but motors just hum louder.
The following is my fcifmdlcnc.ino file
Please help
Tim
Code : Tout sélectionner
void sendMotorCmd(byte cmd)
PORTD = (PORTD & 0x0F) | (cmd & 0xf0); // Directions first!
PORTB = (PORTB & 0xF0) | (cmd & 0x0f); // and step
delayMicroseconds(1500); // eventually wait a little bit <---this worked
// and falling edge of step pulse
PORTB = (PORTB & 0xF0);
}The following is my fcifmdlcnc.ino file
Please help
Tim
The jedicut communication configuration for Clock and Direction must be fixed set to the below values,
only the wires to the specific board may be different -- wire to -->
Function-----------Number in jedicut configuration-----Arduino Pin ------No Wires
(fixed !!)
EngineX1 Clock----------------------2-----------------------D2
EngineX2 Clock----------------------3-----------------------D4
EngineY1 Clock----------------------4-----------------------D3
EngineY2 Clock----------------------5-----------------------D12
EngineX1 Direction------------------6-----------------------D5
EngineX2 Direction------------------7-----------------------D7
EngineY1 Direction------------------8-----------------------D6
EngineY2 Direction------------------9-----------------------D13
All Engines On/Off------------------------------------------D8
Heating On/off----------------------------------------------D9
Heating PWM-------------------------------------------------D10
#include <avr/interrupt.h>
#include <avr/io.h>
// Ringbuffer for the commands
#define CMD_BUFFER_SIZE 600 // must be even !
volatile byte cmdArray[CMD_BUFFER_SIZE];
volatile int arrayIdxRead = 0;
volatile int arrayIdxWrite = 0;
volatile int cmdCounter = 0;
volatile boolean ovf = false;
volatile bool isrActive = false;
void setup()
Serial.begin(115200); // opens serial port, sets data rate to 115200 bps
// pinMode(13,OUTPUT); // Led Pin used for signaling an underflow condition
pinMode(8,OUTPUT); // All axis on/off
pinMode(9,OUTPUT); // PD2, Heat Relay on/off low active for letmathe mdlcnc
digitalWrite(9, HIGH); // Off
pinMode(10,OUTPUT); // PWM for wire heating
analogWrite(10, 0); // Off
// Motor Pins
pinMode(2,OUTPUT); // PB0, X1 Clock
pinMode(4,OUTPUT); // PB1, X2 Clock
pinMode(3,OUTPUT); // PB2, Y1 Clock
pinMode(12,OUTPUT); // PB3, Y2 Clock
pinMode(5,OUTPUT); // PD4, X1 Direction
pinMode(7,OUTPUT); // PD5, X2 Direction
pinMode(6,OUTPUT); // PD6, Y1 Direction
pinMode(13,OUTPUT); // PD7, Y2 Direction
// using timer1 (because timer2 is used for pwm on pin3 and timer0 is used for delay functions)
// using Fast PWM (Mode 15)
TCCR1A = 0x03; // wgm11=1 wgm0=10
TCCR1B = 0x1C; // wgm13=1 wgm12=1 cs12=1 cs11=0 cs10=0 /256 prescaler
OCR1A = 255; // Timer compare register. 255 = 250Hz, 127 = 500Hz, 63 = 1 KHz
TIMSK1 = (1 << OCIE1A); // Timer interrupt enable for match to OCR1A
TIFR1 = 0; // Clear flags.
TCNT1 = 0;
sei();
void handleCommand()
byte val = cmdArray[arrayIdxRead+1]; // The command parameter value
switch(cmdArray[arrayIdxRead])
case 'A': // All Motors on/off
if(val == '1') {digitalWrite(8, LOW);}
else {digitalWrite(8, HIGH);}
break;
case 'H': // Wire Heat ON/OFF (may be programmed as PWM (analog out))
if(val > 0) {digitalWrite(9, LOW);}
else {digitalWrite(9, HIGH);}
analogWrite(10,val*2.55); // PWM for wire heating (stretch 0-100% to a range of 0-255)
break;
case 'M': // Motor step Command
sendMotorCmd(val);
break;
case 'F': // Change the timer frequency, the time between two steps
// OCR1A values 255 = 250Hz 190 = 328Hz 127 = 500hz 63 = 1 Khz
if(val>127) val =127; // restrict from 0 to 127 corresponds to 1kHz to 0.5kHz
OCR1A = 63 + val;
break;
ISR(TIMER1_COMPA_vect) {
if (isrActive) return;
isrActive = true;
sei(); // reenable interrupts, to not miss serial data
do {
// check if the buffer is empty
if((arrayIdxRead != arrayIdxWrite) || ovf)
handleCommand();
arrayIdxRead += 2;
if(arrayIdxRead==CMD_BUFFER_SIZE) arrayIdxRead=0;
noInterrupts();
cmdCounter--;
interrupts();
if (ovf && (cmdCounter<CMD_BUFFER_SIZE/2-25))
Serial.write('C');
ovf = false;
// digitalWrite(13, LOW); // underflow led off
else
// underflow !!
// digitalWrite(13, HIGH); // underflow led on
break;
} while(cmdArray[arrayIdxRead] != 'M'); // only motor commands will wait for next sync, all others can be handled immediately
cli();
isrActive = false;
/**** The main loop *****/
void loop()
if (Serial.available() > 0)
// Each command consists of 2 bytes
Serial.readBytes((char*)&cmdArray[arrayIdxWrite],2);
// korrekt the write index
arrayIdxWrite+=2;
if(arrayIdxWrite==CMD_BUFFER_SIZE) arrayIdxWrite=0;
noInterrupts();
cmdCounter++;
interrupts();
// check for oncoming overflow
if(cmdCounter >= CMD_BUFFER_SIZE/2-20)
ovf = true;
Serial.write('S'); // Stop transmission, Buffer full
Modifié en dernier par Tjmarch le jeu. juil. 27, 2017 7:51 am, modifié 8 fois.
200Hi
Your link seems to be broken. Do you try to use slow speed (high values in jedicut) ?
