Hello.
Am i missing something ?.
I only have a "default" button in the cycle of cut screen. Even this does not work.
For example.
----> I go to the cycle of cut screen after opening a .jdc file
I "delete all"
I create a simple cut cycle.
I then press "default" as this is the only button i have.
It says "Do you want to use this cut cycle as default".
I press "Oui"
I exit cycle of cut screen.
I go back to the cycle of cut screen.
Guess What ...
The cut cycle defined above has gone and i'm back to here "---->"
hELP !.
Rick.
Re: Jedicut v2.3.2 Cycle of Cut.
2I found the problem
In XP, under the Display Properties, Settings Tab, Advanced Button.
I had set the DPI setting to large size (120dpi) instead of normal (96dpi).
The buttons were there, but placed outside the window.
Is this going to be a problem with windows 7 ?.
Bye for now.
Bye for now.
3Hello,
I never try to modify DPI value on Windows. I discover this problem and I will do some research to look at some solution.
I use Windows XP and Windows 8 Pro, I will try and work on it.
