Re: How to get profiles,.dat file extentions to cut
14
Hi,
You don't need profile for your sample of cutting, because it's just an horizontal movement. What don't you understand ? What do you want to cut ?
I'm sorry but I can't answer to your question about "Cut prewiew" bug without more details (what cutting project, what profiles...).
In your Jedicut directory, you can see a Profils directory. It contain some example of dat files.
18
IT WORKED!!! yea.
Thank you Jerome!!!
I kept tring to say -600mm ,Jedicut did not like it very much, now I understand.
Still had an issue but was able to work around it..
I tried check symetrical, without loading the file in the WING tip area, which resulted in a "can't calculate points" error, once I loaded the same file in the wing tip, it worked :).
In the percent window in the wing tip area(usually at 100%) the 1 is covered by a grey box/block.
do not know why??
Once agian Jerome, thank you!
its 11:09 PM and its still daylight :)
